What String Keywords/Tags Does The OBJ importer look for In DAZ?
Hello everyone, I've been playing around with importing objs into DAZ with their textures intact. I've noticed that when importing the normal map will be ignored. Here is an example of one of the mtl lines. This was from 3DS Max.
newmtl Test
Ns 46.4386
Ni 1.5000
d 1.0000
Tr 0.0000
Tf 1.0000 1.0000 1.0000
illum 2
Ka 0.0000 0.0000 0.0000
Kd 1.0000 1.0000 1.0000
Ks 0.2000 0.2000 0.2000
Ke 0.0000 0.0000 0.0000
map_Ka I:\Imports\PNG\Diffuse_Test.png
map_Kd I:\Imports\PNG\Diffuse_Test.png
norm I:\Imports\PNG\Normal_Test.png
From this the "Diffuse" will import correctly but the "Normal Map" will be left empty. Now if I use "Bump" instead of "norm" the texture will be applied to the "Base Bump" in DAZ. I've tried entering other tags like "map_n" "Normal_Map" and "Normal" in hopes the tag will be detected and place the texture in the correct slot. No luck so far. I was hoping that there maybe some sort of cheat sheet showing what tags DAZ looks for when Importing objs. This will be a great help when trying to import large scenes with multiple materials. I did try to reverse it by filling in the slots in DAZ and than exporting as an OBJ, but it makes the mtl super simple.
newmtl Test
d 1
Kd 1.00000001 1.00000001 1.00000001
Thanks for taking the time to read this and I hope that perhaps someone out there will also benfit from this question being asked.
  • crosswindcrosswind Posts: 9,712
    edited October 2023
    'norm' belongs to PBR extension for vendor specific alternation in OBJ format. DS has not supported PBR texture maps imp / export so far for OBJ, while 3dsMax, Maya, Blender, MD, Pt, etc. can...  So nowadays we have to manually assign some maps in DS...
    Post edited by crosswind on
  • BejaymacBejaymac Posts: 1,967
    The OBJ importer is built into the Poser Importer, as a result it's really only going to import settings you would find in Poser, the "simple" material setup (AKA Poser 4 /ProPack surface settings).
  • Aw that is a shame to hear, thanks for taking the time to answer my question folks. Hopefully they update the importer in the future because adding normal maps manually to so many materials sucks.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,525
    I have had normal maps import, in the bump channel mind you but they did import
    depends entirely on the obj AND mtl file, the way they are set out if paths in quotations etc
    a hell of a lot of variation and I have utterly no idea why some work either
