Customising duplicated shapes
in New Users
This discussion was created from comments split from: How to remove duplicates ?.
How do I remove dupicates?? I created duplicate walls of home...and when i try to delete few polygons to create windows...it is getting deleted on every wall...How do I remove duplicates from the other walls?
Split to its own thead as it was not related to the topic of the original (which was abourt "duplicate" enteries in the content panes).
The duplicated items are all pointing back to the same geometry data, and when you use the Geometry Editor it is that shared asset that is being edited. If you want to customise just one of the items you first need to give it unique geometry data first - for example, you could export it as OBJ and then reimport that (File>Export, and set the type to Wavefron OBJ, then File>Import - make sure you use the same preset, probably the Daz Studio one, in both the export and import dialogues).
