Use a G8 prop on a G9 character
Hi all,
I would like to know how it was possible to use a prop made for G8 on a G9 character ?
Is it possible and is there a process to fit or convert the prop ( prop is dForce Linday hairs)
Thanks a lot
Hi all,
Thanks a lot
A hair is rigged, and therefore a figure and not a prop.
You can autofit hair accross generation, e.g. G8 to G9, but the result will differ. Some will be ok, but others will mess up. Custom bones are removed when autofitting.
For using hair on another generation, I would usually just adjust the hair to the chcaracter, and then parent to the head.
Real props (i.e. without rigging) can be used accross generation as there are not figure dependant. Smartprops, that e.g. can load onto the figure, will not work if the characters have different rigging.
