Mirror Shader for Iray.
A free mirror shader for DAZ4.8 Iray render engine. Hope someone finds it useful.
Can be found here. http://www.sharecg.com/v/81125/browse/21/DAZ-Studio/Iray-Mirror-Shader
Sweet thanks, I will see if it is the same as mine I made.
Thanks aaron575
I will let you know tomorrow when I get a chance to check
Your is totally different from mine and so much better, thank you.
You're most welcome Szark, I am amazed at the views and downloads and it hasn't been there 24 hours yet.
my pleasure. I would have never thought of use the top layer for a Mirror.
I don't know it gives a nice finish. :)
And I am not a good judge, I need new glasses and just can't afford them at the moment.
The reason i used the top coat was, it was the only place I could set the refraction to 1 to give crisp reflections. Well that's my way of thinking
i am probably wrong.
You can't be wrong if it works. :-) It may or may not be optimal, but it isn't wrong!
You can't be wrong if it works. :-) It may or may not be optimal, but it isn't wrong!Thanks for that. :-)
I will say air has a refraction of 1 so in this case it probably wouldn't do anything.
Thanks everyone, I am really happy with the interest you have shown. 500 downloads so far, I am truly amazed. I thought it would just get lost in the gazillion other resources on the site.
You have all made me very happy. :-)
this is awesome... thanks so much!
Very much appreciated. Thank you!
When its good...its good i have used this shader so much because it really is good. I think the thing i like most about it is the fact that its not 1:1 when it comes to lighting. The light in the room is subdued in the mirror substance just like real life.
Your shader in action.
Daniel
One difference I see with your shader is that the illumination looks more equal to the lighting in the scene. Most shaders I've used in the past, the reflection looked dark. This looks right on the money. Really good work! Thank you so much!
Excellent work; thanks for sharing! \o/
Thumbs up here !
Thanks
Thanks a lot.
