Script dropdown menu stopped working
Hey, i have a realy odd problem, my script dropdown menu stopped working, but when i run a scripts from my library - it works just fine, no problem at all.
I added a new Script to the pane, and surprise surprise - i can run it from there. but the old scripts - no chance.
Anyone here who had the same problem?
The Scripts menu is just a set of pointers to the script files (or sometimes a script embedded in a custom action) - the menu can go if the menus.dsx file is overwritten or corrupted, and if the target files are moved then the custom actions will fail and their menu entries will be suppressed. Window>Workspace>Customise will let you check that the actions can find their target files (Custom group on the left) and that the menu is correctly placed and popuulated (Main Menus>Scrtips in the Menus tab on the right).
Thanks, somehow the file path was changed - I have the scripts on a different hard drive than DAZ. But suddenly it was the path for DAZ - strange
