Genesis 2 Female Missing
in New Users
Hello. I installed Genesis 2 Starter and Genesis 2 Male appears just fine. However, I can't find the Genesis 2 Female figure. Can anyone help?
How did you install? Male and female are separate packages when using DIM/Daz Central. And where ar you looking - Smart Content, or Content Library under Daz Studio Formats?
Hello Richard. I located the Genesis 2 Female figure in the Content Library, However, it doesn;t show up in Smart Content.
OK, try reimporting metadata (Content Library option menu>Content DB Maintenance and check Reimport Metadata, then select the Genesis 2 Starter Essentials product). Sometimes having the two packages for a single product does seem to cause confusion.
Hello Richard. I tried your suggestion and still noi luck.
You have the current vesions of the Starter Essentials packages? If so I don't know what could be going wrong.
Thanks anyway Richard. I really appreciate your time.
Hi.
I've updated the software and also couldn't find the Genesis 2 Female base figure in my Smart Content. Did also the Reimport Metadata but nothing.
But checking manually I found it here: Smart Content -> Scene Builder -> Genesis 2 Female Base
Seems they moved it there, at least in my computer. And is weird because the Male version appears where it has been always, under the Figure section.
That is a folder on disc or a category?
Thanks for this, I too was not able to locate Genesis 2 Base Female, Your steps helped me out.
Thank, I think they reversed the location of Barefoot Dancer and Genesis 2 Base Female. The figures appear to be the same, but I Zero the properties out to be safe.
