Can I convert my old V4 textures to Iray?
Jan_Scrapper
I love my textures for all of my many, many figuews, however I will just ask about V4.
I have so many wonderful textures like all of Maddelirium and Thorne and Fabiana and so many more.
I have purchased several skin converters. However, it's the wonderful skins with tattoos and the eye makeup. Those don't convert, or can they?
Post edited by Cris Palomino on
...there is a product in the store that will do just that. Only 3.99$ right now,
https://www.daz3d.com/iray-converter-for-generation-4
Thank you both so much!!! I will check these out!!
It's not the textures that need converting (though older materials will not have all the map types that the Iray shaders can use) but rather than materials. Most will be using the standard Daz shaders, or will be in plain Poser format and will get converted to the base 3Delight shader which will then be converted to Iray settings at render time, so the only reason to manually convert is if you wish to adjust the settings.
There is a generation 1 genesis version that also works for Genesis 2, allowing those older products to render with Iray as well. Iray Converter for Genesis | Daz 3D
