Multi Bulge for G8M, G8F and G9
A while back, I ran into the issue that most of the groin bulge morphs for Genesis figures fall into one of two main categories - vague shapes that only look right under thick clothing, or more defined shapes of utterly gargantuan proportions and only one pose.
So, I ended up creating an adjustable groin bulge for G8/G8.1 and G9 - both male and female are supported on G8 (either for transgender characters or cases where you need to use the other base for technical reasons).
These morphs are only intended for use under clothing, as they don't actually add any geometry, just morph the figure - but controllers allow adjusting of the strength, length and position of the bulge, as well as separate adjustment of testes size/prominence.
The various controllers are called "SM Gens Bulge" and can be found under Actor/Hip/SM Gens Bulge.
More details can be found in the included readme.
Download Link
I'm giving permission to store, access, use and modify this content for personal and/or commercial renders, with no royalties or credit required.
Redistribution of the contents of this package is however not permitted in either original or modified form without my express permission.
  • Thank you very much!
  • SquishySquishy Posts: 719
    This is great, nice work :)
  • HylasHylas Posts: 5,245
    Love it, thank you! yes
  • Nice one, just what I needed, thanks.
  • Ooh, was looking for something like this recently, TY. Was planning a scene involving a character in budgie smugglers, but there was a noticable lack.
  • leo04leo04 Posts: 389
    edited November 2023
    Good Job!  I have been struggling with this issue and you solved it.
    After I installed it using the Content Package Assist program I realized there isn't any interface in DAZ to apply it
    Since it will always need to be part of the character I just selected all of the files and dragged them onto the character.
    It works and that is all I need, and I made it part of the base character.
    Thanks!
    PS Surprised this wasn't included in G9.
    Post edited by leo04 on
  • RAMWolffRAMWolff Posts: 10,363
    BULGE-TASTIC.  Thank you
  • Matt_CastleMatt_Castle Posts: 3,046
    If you're talking about library presets, I didn't set up any partly because I seldom use them myself, partly because because the shapes are supposed to be a spectrum that can be dialled to taste, rather than having specifically "right" values.
    Indeed, part of what I was trying to prove was whether you could have a shape travel smoothly across the surface of a model (without dragging vertices with it), so it's expected that a lot of these controls might be dialled in to fractional numbers.
  • Thank you, I like it... I think the bulge could be longer for G8M :-)
    @Dissendior - there is a controller that does lengthen the shape somewhat, but for the most part this is intended to be a fairly low key morph - something for when there needs to be some shape to stop a character looking like a Ken doll, rather than as a precursor to a smut scene.
    If you need morphs for people smuggling foot-long subs down their trousers, I'm sure others out there have made such morphs with rather more enthusiasm than I could bring to it.
  • t.d4722t.d4722 Posts: 0
    Sorry I am new to this. Can someone explain how I install and apply this please?
  • Can someone explain how to apply this? Checked the Parameters tab, tried applying one of the broken looking items from the content library and it doesn't seem to work.
    Thanks!
  • LorraineLorraine Posts: 912
    Thanks!
    Load your genesis male, go into parameters, type 'bulge' into search at the top of the list of parameters, look for SM Gens Bulge and its stable mates, push the slide to 125%, go "wow!"
  • Lorraine said:
    Thanks!
    Thank you so much for the speedy reply. Unfortunately, this is what I get:
    364 x 517 - 48K
    230 x 857 - 54K
  • AH! I got it lol. Had to reboot. Thanks so much for this :)
    Pedantically, it's not exclusive to the male. (Indeed, the original version is actually the G8F version; I made it for a transgender character).
    But yes, you want to be looking for "bulge" in the parameters section, and probably also want to experiment with the various adjustment sliders to see what gets you the results you want.
    For technical reasons you can't really go outside the limits I've set on the sliders (it's actually many morphs being dialled in and out by a controller rather than a single morph that's moving across the surface), but you do get quite a lot of adjustment within that range.
  • rosselianirosseliani Posts: 508
