iray render color issue
I reinstalled daz on windows 11 and the render is like this. I cannot find out the reason.
The light is ok, in fact this is a product ready scene without any editing
  • crosswindcrosswind Posts: 9,712
    It's an issue from Nvidia driver... If you turn on the filter - Post Denoiser Denoise Alpha in Render Settings, you'll get such a blueish result... just turn it off.
  • prixatprixat Posts: 1,617
    Looks like the bug in Noise Reduction.
    Switch off the 'Alpha' option and you can still use Noise Reduction.
    Thanks a lot, It is the driver problem. I installed the studio ready drive and problem solved. THANKS!
    Thanks, I solved it, it is the nvidia drive problem
