Looking for A Good Double Barrel Shotgun model
Does anyone know where I can find a good double barrel shotgun model for daz? For clarification I don't mean a sawed off shotgun (found plenty of those) I mean a full-length, double barrel shotgun. The only one I've been ever to find was from this pack:
http://www.renderosity.com/mod/bcs/mocks-groovy-zombie-bashing-set/27837/
Its perfect, but its Poser only (which I don't have)
Does anyone know of a Daz-compatible double barrel shotgun (non-sawed off) on here or somewhere else? I know that Daz shop's search tool is kind of unreliable and doesn't show every possible option.
Most of Mock's stuff will work in Studio, just needs some materials tweaks.
That said, check out these...
Classic side-by-side...
http://www.ontarget3d.com/site/Products/1028-coach-gun-for-poser.aspx
And an over and under...
http://www.ontarget3d.com/site/Products/1072-over-and-under-shotgun-for-poser.aspx
Not quite a double...but the classic pump...
http://www.ontarget3d.com/site/Products/1019-win1897-for-poser.aspx
Might be good enough for you:
Deividman's Double Barrel Sawed-off Shotgun:
http://www.daz3d.com/deividman-s-double-barrel-sawed-off-shotgun
Stagecoach Action (includes a bonus Double-Barrel Shotgun):
http://www.daz3d.com/stagecoach-action
Thanks for the links but the shotgun in Mock's gun pack is what I need, but can you tell me how I can tweak the materials so that they can be imported into Daz? I bought this gun pack without realizing that i was Poser only, but if you could tell me how to tweak the materials to make it Daz friendly that would be great!
I don't have that set, but I do have some of his other guns, but I don't have them installed at the moment. I'll install them and see what tweaks they need. Most of his stuff is similar as to the way the materials are set up.
Yeah, I mean if you can tell me what steps I need to take to tweak Mock's stuff so they can show up in DAZ that'd be fantastic! I've tried adding them to the files and folders but I can't get DAZ to recognize and accept them.
First, you need to make sure that you have a mapped Runtime, under Poser Formats in your content directory manager (F2 or Edit > Preferences). It can be the 'default' Runtime in My Library, but for non-DAZ store items, it's advisable to add a new one. (1 & 2) Then you install the files in the zip, into the runtime folder...if it unzips to a top level folder named Runtime, you install the files IN that folder to the mapped runtime folder.
Then, to find them in Studio, you need to look in the Content Library, not Smart Content, under Poser Formats, in the library you mapped (3).
Then a test/spot render to see what materials will need to be altered. (4)
Usually, specular strength, glossiness and ambient are the ones that will need to be altered.
