How to find a viking hammer tatoo for Gen8 m and f?
I've been looking high and low, but no joy. I was looking for something similar to the attahed image,
  • felisfelis Posts: 5,962
    You could take that image into an image editing orogram and edit it so you could use it as a mask in LIE.
  • caravellecaravelle Posts: 2,677
    This suggestion is the best. This way the OP can use the (very beautiful) original motif and does not have to scroll through the shops for hours only to not find what he/she is looking for in the end.
    edited September 2023
    Quick test (can only rotate in steps of 90 degrees in LIE, so should be adjusted in an image editing program.
    1200 x 1200 - 2M
    Post edited by felis on
  • FirstBastionFirstBastion Posts: 8,049
    You can also try an iray decal node, or apply to texture.
    [edit add]
    learn the technique and  you will be able to add the tattoo yourself
