RTX 3060 not listed in Render/hardware
Hello,
As I'm progressing little by little with Daz Studio, I've just bought an RTX 3060 12GB graphics card to go further (until now I only had an AMD GPU integrated into the CPU, which was enough for everything else than Daz Studio). I've installed the latest nvidia drivers. I do have "Allow GPU detection" and "Check GPU driver version" checked in the render panel.
But the card is not listed in the render/advanced/hardware panel (NVIDIA Iray engine selected). As a result, it's not used, and rendering is as slow as before.
However, the card is visible in the simulation/advanced panel and dforce now works.
When I go to Help/Troubleshooting/About your video card, the card is visible and everything seems ok except that pixel buffer size is "not enabled" (?)
I didn't see anything in the logs and didn't found anything usefull on the web.
What could be the possible reasons for Daz Studio not listing the card ?
Which version of DS do you use?
Support for the 3000 series cards was introduced in Daz Studio 4.14, I believe. If you are running an older version, that is most likely the problem. I think Leana is probably on the right track.
I'm running DS 4.21 pro.
For completeness I also forget to mention that I'm running DS on linux throught wine.
You may want to look at https://www.daz3d.com/forums/discussion/60901/daz-studio-and-linux
Yes, definitely the right topic. I saw it after I posted last night. Thanks!
