Genesis 8 Male Fig neck problems (geometry)
Hello i have a problem realy weird here. and i don't know how to solve. But i just realize that when i rotate the head of the genesis 8 male fig to the X -30.00 this weird geometry go crazy. and this is just the basic figure i don't even aply any morph. some one can help me here a realy appreciate it.
Weird geometry bug:
https://drive.google.com/file/d/1iwJRdwHsnrFKWs9hyhQNJ4u8Fnmf9azN/view?usp=sharing
With out rotate the head:
https://drive.google.com/file/d/1AuWgBEcpPIk6Oxwnr3_ZE2ztMys-zVhq/view?usp=sharing
There must be some character's morph(s) wrongly dialed as default. Reset pose, select Currently Used (with Show Hidden Properties), check if there's any character or weird morphs dialed.
Most likely it is a corrective morph, to make the bend look good when there is a very different character shape applied, that is kicking in when it shouldn't (i.e. when the shape it goes with is not applied). Apply the minimum pose that will trigger the defect (the -30 X bend on the neck) and then seelct the figure and follow what crosswind wrote about identifying hidden morphs that are in effect - one of those will belong to a character set and that is almost certainly the culprit. Check if there is an update for the character, if not report it (to the maker for other stores or freebies or to Daz for products sold here).
