Natural Movements Pack for Genesis 9
13»
  • TimbalesTimbales Posts: 2,432
    barbult said:
    Timbales said:
    Bunyip02 said:
    Timbales said:
    I'd be interested in a JCM set for G9 Masculine. This one says it's for Feminine, I assume that it works only on feminine shapes and isn't a universal product.
    Works on male as well.
    Screenshot does not show them very well, but noticeable changes in the armpit & thighs
    Noticeable changes in shoulder blade, also changes to thigh.
    Based on the hip with it applied, I'd say it doesn't
    It "works" in the sense that the morphs can be dialed in, but whether they look good when dialed in on characters they were not designed for is another thing. In this case, I agree that the hip does not look right with this morph combination.
    That is the point of Genesis 9. Pointing out that something made for Genesis 9 is technically compatible for Genesis 9 adds no value.
  • barbultbarbult Posts: 26,489
    Ouch! I was simply agreeing with you.
  • NinefoldNinefold Posts: 256
    edited December 2023
    My favorite part of this pack is the hands, which are so good that they may fully convert me from a G8 user to a G9 user, except for this weird problem with the first knuckles of both ring fingers.
    This just looks like a mistake to me. This JCM clearly doesn't match the ones for the JCMs on the fingers to either side of it. It looks fine from the top, though:
    Zeroing it makes it look better from the side and worse from the top:
    On a hunch, I tried just making the value negative, which looks even better from the side (though you can tell something is going wrong between the middle and ring knuckles) and even worse from the top:
    It sort of looks like this morph was constituted from two other morphs, and one of them was dialed in the wrong amount (perhaps a negative number) when the final morph was created. Because it is a single morph, though, the end user can't fix this problem by fiddling around with dials. I would love to have an official fix for this. It's the only thing that's stopping me from using this product absolutely all the time.
    991 x 875 - 141K
    991 x 875 - 90K
    991 x 875 - 141K
    991 x 875 - 87K
    991 x 875 - 142K
    991 x 875 - 87K
    Post edited by Ninefold on
  • VisuimagVisuimag Posts: 578
    Elor said:
    outrider42 said:
    I have seen Genesis 9. Genesis 9 has World Devouring Thighs. Actual promo pic for a G9 product in this store:
    It's not the base Genesis 9 figure and in a direct comparison, with Genesis 9 (with Victoria 9 mats) and Genesis 8.1 (with Victoria 8.1 mats), the difference isn't that big (I tried to reduce G8.1's height a bit but I don't know what percentage I needed to remove):
    I don't get why the existence of products like Natural Movements or UNBM for Genesis 9 is seen as a defect of G9 when similar products are also available for previous generations too.
    Totally agree!
    Every generation gets the same kinda nonsense about how "it's a regression, the previous generation was better." With mentions of the same kind of corrective products that come out every generation because they all need them.
