Fit Control Genesis 9 Male & Female Edition (Commercial)
Zev0
Zev0
Please be fit control for Genesis 9
This is getting more and more exciting.
You read my mind!
I'm exited too, please let it be skin builder 9 pro for hyper realistic skins. I would be happy to spend lots of $$$
"Hi Guys. Myself and D.Master have formed a new partnership so we will be releasing the Genesis 8 Female version of Auto Muscle Enhancer, and a Genesis 9 version. After that we will see what else we can bring to the table. Just thought I would keep you guys in the loop.
Either one or both? !! TD
It is for Fit Control G9 but I can only officially rename thread once product has been approved.
I was hoping for this also since I have never had a need for fit control
I see the thread got renamed, which presumably means this is now approved! Looking forward to purchasing this in the coming days! The last really critical piece of the puzzle for G9...
Excellent! :)
Will only be released next month.
It does contain pec adjuster morphs.
You're welcome.
And the sooner the better! For some reason, Projection Morph Manager is going into a death spiral on G9 right now. Rebooted machine, run it again, just the constant hourglass forever, stating it is "Checking out the projection morph structure"... and stuck at 0% forever. Any clues?
Ok, so update on the above issue. I spent a couple of hours this evening stripping the problemmatic character back to basics - deleted hair, geografts and then gradually, one set at a time, zeroing out the morph parameters. The set that made the difference - the only set - was Zev0s "Growing Up for Genesis 9". Zeroing these out and things started to work - the Porjection Manager ran just fine. Just as a final check, I loaded the original character with the problemmatic clothing, and zeroed out just one parameter: the Growing Up parameter "GU Youth Base Morph". Dialling it in again and re-running the projection morph manager caused it to fail once again, hanging Daz Studio exactly as before. Is this a known problem? Or unique to me for some reason?
Ok, trying to attempt to make this a repeatable problem for testing purposes. Load G9 base figure (not the developer variant). Select Base Feminine morph parameter to 100%. Set Growing Up morph parameters as shown in attachment. Load clothing item - xtrart DForce X-Fashion Oversize Jogger/XF Oversize Bra. Select Oversize Bra. Run Projection Morph Manager. It hangs Daz Studio requiring a forced quit. I'm running the latest non-beta Daz Studio on a macos Ventura, running M2 Max processor. I have not yet tried this with other clothing items. Hope this helps diagnose what is happenning here.
Thanks for taking this forward! And as you say, easy to work around now we know the culprit. Initially, I was faced with dozens of morphs with no clue how to resolve, other than methodical exclusion one by one... I have a bad habit of just messing about with dials until I get the look I want, which results in too many dialled up, really.
Can confirm this is happening with this particular combo..We still don't know why yet........
I'm sure you are incredibly busy with G9. This can wait, at least speaking personally, now we have a workaround.
Any chance they will have movement morphs for underwear and swimwear that stops the stretching effect when moving the legs? Undergarments tend to stretch a little and look really weird when you change the legs poses, almost like it is shrink-wrapped to the skin of the leg. Figures in example are G8 (Armand), G8.1, and G9. in all tests across all figures this happens, with multiple garments from multiple 3D artists. Any help? and can Fit Control 9 help?
Hi. I think you can actually use projection morph manager for that or manually find the hidden leg bend dial on the underwear and set it to zero.
https://www.daz3d.com/fit-control-for-genesis-9-bundle
https://www.daz3d.com/fit-control-for-genesis-9-feminine-edition
...just noticed that the product page didn't link to this one.
j
I keep getting this window when selecting my G9 character and selecting the + script:
"Installation Error: Fit Control not found on Genesis 9."
Tried multiple time installing and uninstalling just in case, but no matter, tried with multiple G9 characters, same result, even the base one.
