listing out properties.
Fugazi1968Fugazi1968 Posts: 29
edited December 1969 in Daz Script Developer Discussion
Good evening all
Forgive my noob question, but is there a way to list out the properties of an object via a script?
var nodes = Scene.getNodeList();
var obj;
for (var n=0 ; n {
obj = nodes[n].getObject();
(loop in here to print out each property)
I hope that makes sense.
Many thanks
John
  • Richard HaseltineRichard Haseltine Posts: 108,773
    Anything derived from DzElement has a getPropertyList () method that returns an array. DzObject has getNumModifiers () which returns a number, you can then iterate over that and use getModifier ( Number ) to get the modifiers for the mesh. Don't forget to check that obj is valid before trying to do anything with it.
  • Fugazi1968Fugazi1968 Posts: 29
    Thank you very much Richard, that will help tremendously
    John
  • rbtwhizrbtwhiz Posts: 2,485
    Review the Node Properties sample.
    -Rob
    Brilliant Rob, that will be very useful indeed.
    John
