Light Panel Obj
Catherine3678abCatherine3678ab Posts: 8,556
edited August 2023 in Freebies
Basically, just the .obj to use as a light panel in D/S or any other program you want. No textures or other scene stuff included.
In D/S, import using Daz measurements, resize and position to where you want it ... hiding or removing all else from the scene, export out the .obj. Then remove that from the scene. Import back in your new .obj file; apply desired shader presets etc. and save as a Figure/Prop to a sensible location.
UVMapped so one can use texture images.
At Renderosity.
Post edited by Catherine3678ab on
