can the content library be made to resolve shortcuts?
It's not possible to put my 200 g of old saved render files etc on my content directory drive but putting a shortcut to that folder in the content drive doesn't work as the CMS apparently ignores short cuts?
  • NorthOf45NorthOf45 Posts: 5,900
    Why not just add another Library? Studio will search all mapped directories.
    Are you trying to inject logic into this discussion?
    My thought train went askew when I discovered there was no way to add the 250 g render file save folder onto the m2 drive ... because not enough space so was going with short cut but then adding a directory is actually a shortcut ... and duh I have over a hundred mapped directories.
