Categories and sub-categories in the Smart Content tab are not sorting?
The Smart Content database tab is not showing sub-categories sorted.
For example, when I add a new sub-category under Default within the Content Library tab, the new category correctly sorts within the Library tab, but, when I switch back to the Smart Content tab, the new categories drop to the bottom of the list.
How can I sort the Smart Content tab?
  • crosswindcrosswind Posts: 9,639
    Yes, that's normal... The user defined Categories (there's a U mark on the icon) are sorted along with the Default Categories from Daz in Content Library (under Categories), while they are not sorted in the same way but being placed to the bottom in Smart Content.
    I myself prefer such a way. Well, there's no standard function to change this way of sorting. The only way is to change a field value in CMS database, but not really recommended...
  • CA415CA415 Posts: 165
    Thanks for the feedback.
    How do I change the field value in the CMS database?
    Pls check your PM...
