Fiber mesh brows and lashes - how to
daveso
in The Commons
How to you create fiber mesh brows and eyelashes? There must be a technique to do it, I would assume. any tutorials?
Using the Strand based Hair tools in DS, or an external application that will export lines to OBJ. Brows and lashes require no special tricks.
How do you get an imported (line) obj to be accepted as strandbased hair?
You don't, in the sense of being able to edit it with the editor, but it is still a curve rather than a strip or tube (given suitable export options) and so can be rendered as such.
Allegedly, Daz PA's are able to import polylines (or something to that effect) into Daz to be converted to SBH.
For normal users, to make eyelashes and eyebrows in SBH Editor, you can just create them as you would any other type of hair in SBH Editor.
Attached is an example of eyelashes I had created in SBH Editor. The SBH were made on a eyelash scalp that gets fitted to the Genesis 9 figure and then hidden.
