Super long nails and muscular body for g8/8.1f problem
Hello
When I load any g8f or g8.1f they have super long nails and muscle bodies, there is no way to remove them till I zero figure shape. what should I do to solve this problem?
Thanks a lot
Hello
Thanks a lot
Image removed
To fix any ill-behaving (non-zero default value) morphs, do as follows;
1. Open DS and load "Genesis 8.1 Basic Female" (to an empty scene)
2. Right Click at Parameters Tab->Preferences->Choose "Show Hidden Properties" (part 3 zeroes only 'visible' dials)
3. Right Click at Parameters Tab->Zero->Zero Figure (Zeroes the value of all the 'visible' dials)
4. Right Click at Parameters Tab->Memorize->Memorize Figure (Sets the current value of all the dials as their default value)
5. Edit->Save As->Support Asset->Save Modified Assets (Writes the changed default value to the morph files that were changed)
When saving "Modified Assets" DS shows a dialog and asks for confirmation;
"The following file(s) will be permanently modified:" - "Accept/Cancel" - Choose "Accept"
Please don't post textured, nude figures.
Make a note of what is being saved heer, if they are the names of store products or freebies check for updates that may fix the issue anyway.
Thanks a lot!!
