Can I Transfer Certain Bones Only to My Cloth?
James
After some testing... I think I need some bones I've deleted.
Is it possible to transer certain bones only from G9 base to my cloth ?
I don't want to ruin all the weight map, I've set and start all over again by using transfer utility.
Post edited by James on
I did remember that you had deleted some bones from the hijab... You just need to use Transfer Utility to re-transfer the Weight Map from G9 to the garment, then modify the bones again as you wish. If you've ever painted some weight maps, first hide the relevant face groups with Geometry Editor, then use the settings as below -:
In case there's any wrong weight, you still may copy the weight maps from the original Hijab to the current one.
Don't remove "too many" bones -- clothing bones always go through to the "hip" and this is required to permit the garment to grow with character changes.
