looking for a plain white paint shader for a wall
Toobis
I'm basically after just a shader that is white paint for a wall (not a brick or rock patterned wall or anything) just a plain no lines wall. Can anyone suggest anything? thx.
I'll try this thanks.
There's a little strength applied to the 'metallic flakes' part of the uber shader which can occasionally look a bit strong, but in normal lights it just looks a bit like some texture. I got the wood chip effect on the peach section of walls with a noise map put into the bump & normal channels. That idea could be toned down too.
Regards,
Richard
Honestly, when I need something simple I use this shader set: https://www.daz3d.com/pd-iray-shader-kit-1
But these could work too:
https://www.daz3d.com/architectural-iray-shaders
https://www.daz3d.com/decorator-kit-neutral-shader-presets-for-iray
https://www.daz3d.com/ptf-interior-design-shader-kit
