Problem with getting to work ‘PTF magic shaders and wearables for G3 and 8’
Hello to all,
I recently brought 'PTF Magic! Shaders and wearables for Genesis 3 and 8', installed it and tried to use it on both g3 and g8 following the instructions to the T.
No matter how many times I try or if I reinstall it, I get the same result. I apply the 'right arm' present, choose air flux , go to mask part of the arm.
Everytime the magic appears around BOTH  arms and the materials for the body disappear ( I can reload them, but if I do, the magic disappears along with them).
Just once I had a fluke of luck where it was all working the way it was supposed to but daz shut down within seconds. No idea of whether that one time I did something different by accident.
Someone here has any idea of how I can move from here or what is happening?
  • Richard HaseltineRichard Haseltine Posts: 108,455
    That sounds as if you are applying materials/shaders meant for a shell to the base figure.
