How Compatible is D|S 4.8?
acanthis
Post edited by acanthis on
acanthis
Chances are that you'll find it will render faster...
There have been several improvements/speed tweaks to 3DL between the build in 4.7 and the build included in 4.8. I've not run into any problems so far.
@acanthis: 4.8 3delight is visibly faster than 4.7 one; I would have upgraded even just for that.
You can also find information on IRAY here. We've listed various threads and pages of interest in the interest of keeping information in a few places rather than having dozens of threads to have to search through.
Thanks for the link. I'll read through them, but my primary concern is maintaining compatibility with work already in progress. If there is a speed-up in 3Delight that would obviously be nice, but not if anything (shaders, lights etc) has been broken by the upgrade and would therefore require me to spend time and effort adapting to those breakages.
For me, iRay comes later - a couple of releases down the line, when the inevitable bugs and unforeseen side effects have been ironed out, and I can afford to spend the time converting every single surface on every single object in my entire content library so that they can actually be rendered!!!!!!
Whenever you decide to upgrade, as discussed in another thread, take a copy of the zip file needed to install 4.7. That way if 4.8 does cause you serious issues, you can always uninstall, and then reinstall 4.7.
