Smart Content Going Crazy
NoName99NoName99 Posts: 322
I installed 4.8 with DIM, and now everything in Smart Content is out of order and with a yellow triangle exclamation point.
I re-imported meta-data but it didn't work.
Preferences > Content Libraray > is pointing to the correct directory.
I uninstalled both PostgreSQL Valentina Conversion and PostgreSQL 64-bitand Re-Installed them both.
Still not working.
I've had smart content problems in the past, but this is the first time I haven't been able to fix it.
If anyone has any suggestions please let me know.
  • barbultbarbult Posts: 26,537
    Have you checked the content directory manager to be sure your content libraries are listed in the DAZ Studio Formats list and Poser Formats list? Are your content directories on an external drive that is not attached at the moment (that happened to me).
  • NoName99NoName99 Posts: 322
    Thank you for replying.
    Yes, everything shows up under content library, under both Daz Studio Formats and Poser Library.
    I see there is a new file I have never seen before. CONTENT CLUSTER
    Content Library > Daz Studio Formats > My Library > Content Cluster
    I strongly suspect this has something to do with it.
    I suspect if your CMS now stop, have you re-start postgre CMS already?
    Rclick content library tab>start CMS (or stop and start CMS again)
    to use content library we need not to run CMS.
    And if CMS run already,,
    the yellow triangle exclamation point is usually orphan files,,
    there is only meta-data, but miss location
    from Content Database Maintenance,
    you can remove Orphaned Refelence too.
    (but I do not have such Content Cluster files,,)
  • Richard HaseltineRichard Haseltine Posts: 109,357
    If you are getting items in Smart Content, Categories and Products then the CMS is running but the files aren't where the CMS says. You tried reimporting metadata, but did you rest the database first to clear the old entries?
