Lighting
Why do I not have environment lighting in Studio 4.21 ?
  • FirstBastionFirstBastion Posts: 8,049
    There is a default HDRI that lights the default empty scene.
    The only way you do not have that lighting is if you loaded something that is blocking the environment default light.
    What did you load?
  • FishtalesFishtales Posts: 6,215
    Are you getting a black render when you add a HDRI? I have been getting that for months and then every now and again it works. I revert back to 4.15 if it keeps doing it then try again a few days later and see if a new HDRI works. Sometimes it does more often it doesn't. I am only using the beta for that reason.
