Help request - Dupliacte ID
Haruchai
I am getting a duplicate ID warning when I load Genesis 2 Female (or any character duf that calls the file).
I have looked in the log file and found out which file is causing it, tried to use Richard Haseltine's fix script but this gives an error, see attached pics.
I have tried replacing the file from the zip in case it was corrupt but this has had no effect.
Has anyone any idea what I can do to resolve this?
Have you downloaded and installed the latest version of Genesis 2 Starter Essentials from the site?
According to DAZ Install Manager yes. Would you recommend redownloading from product library and manually installing?
Edit - Reinstalled Starter Essentials, issue still exists. Thanks for the suggestion though.
Do you have the "Growing Up" morphs installed? If so, try uninstalling those from DIM and reinstalling. Those cause me the exact same errors every time G2 gets updated.
It may well be the Growing Up morphs, but if you have already installed the new version without uninstalling the old then uninstalling won't help. Before doing anything else load G2F then open the log file (Help>Troubleshooting>View log), scroll to the end and work your way back up until you find the name of the .dsf file that is causing the error.
Thanks for the responses. Yes It is the Growing up morphs, in particular the Head Proportion file that the log file points to, see pic 1 above for the log file.
I have solved it, thanks for the advice.
Here is the resolution in case anyone else has this issue and reads this. I uninstalled the Growing Up morphs via DIM but before reinstalling checked the data folder. Sure enough there was still a folder containing 2 files 'Eyes Closed More' and 'Head Smaller'. Deleted these and reinstalled. Problem solved. I'm guessing that the 'Head Smaller' and 'Head Proportion' were conflicting as they are roughly the same size and indicate to me that they do the same thing. The two orphan files must have been left over from a previous install .
