How is it done
sheedee3Dsheedee3D Posts: 214
I have purchased several 3D car models...but i havent got a clue how to get the wheels to turn...like seen in this promo.
The car looks much more realistic with the wheels rotated.
How is it done?...
  • BeeMKayBeeMKay Posts: 7,019
    edited May 2015
    That depends on the model.
    The first option would be to select the car, and then check in Parameter tab if there's anything under "actor" like "steering wheel".
    The second option would be to select the wheels themselves, and see if the provide any movement. If it's not named, there is sometimes the option of "bend" or "twist" that gives the desired result.
    If it is just a static model, with no functionality, I guess you have to create a morph on your own?
    EDIT: For example, this model has vairious moving parts:
    https://www.daz3d.com/llamaghini-gallopngo
    And this one, even thoug it's old, also has moving parts:
    https://www.daz3d.com/1957-am-convertible
    Morphs (with Limits Set)
    •LFDrum: Turn LFWheel, Rotate LFWheel
    •RFDrum: Turn RFWheel, Rotate RFWheel
    •TurnFWheels: Turn Front Wheels (Including Steering Wheel)
    •RDrums: Rotate RearWheels
    •RotateWhls: Rotate All Wheels
    •Left Door: Open LDoor
    •Right Door: Open RDoor
    •Left Glass: Open LGlass
    •Right Glass: Open RGlass
    •Left Wing Window: Turn LWing
    •Right Wing Window: Turn RWing
    •Hood: Open Hood
    •Trunk: Open Trunk
    •Steering Wheel: Rotate Steering
    Post edited by BeeMKay on
