Show Us Your Iray Renders. Part III
1303133353650
  • KhoryKhory Posts: 3,854
    I’ll note, in case it wasn’t obvious. that I didn’t design the robot (I rarely make models)
    Not to worry. I was complementing the use of shaders and your render.
  • L'AdairL'Adair Posts: 9,479
    Holy Cow!
    4.8 has just been released... and there are a number of new products just for Iray! Woohoo!
    Must go check them out...
    These are just the first wave. I know there are more for tomorrow as well.
  • TenmaruTenmaru Posts: 105
    Sooo looking forward to Unshaven 2 with Iray Hair presets :roll:
  • namffuaknamffuak Posts: 4,443
    We're all going to go bro-oke!
    Ah - maybe. My credit card just let out a shriek and ran outdoors.:P
  • MEC4DMEC4D Posts: 5,249
    Yeah Unshaven 2 ready for tomorrow May.27 ;)
    guys the manager installed 4.7 without Iray what is going on ?
    manually it give also 4.7 option
    edited May 2015
    It's like Christmas in July, only early. ;-)
    So many things to buy, so little money...
    I've got some store credit I've been holding onto just for Unshaven 2. Like you, I hope it's released soon.
    LOL, Mine, too.
    Will our wallets/pocketbooks survive the next few days?
    Post edited by L'Adair on
    Hallelujah!
    And a few other exclamations not appropriate for mixed company, (or the forum!)
    Not working for me either. Store glitch as always? I guess I'll sleep on it anyway
    Greetings,
    I'm fairly sure they didn't manage to put DAZ Studio 4.8 in the hopper to release; I'm also sure that'll be fixed in the morning.
    I'm glad it's just the first wave; it's a little too HDRI-heavy for me. I'd love to see HDRIs mixed with matte objects for complex shadow-catching... I picked up a few nice things, though, and I'm looking forward to more shaders!
    -- Morgan
  • JimbowJimbow Posts: 557
    Ta very much, Cath :) What period are you making?
    MEC4D said:
    Wonderful work Jim , remaking myself English historic uniform right now too
    Jimbow said:
    My first napoleonic render in iray, using one of the hi-rez HDRs from NoEmotion for the distant landscape, sky and lighting:
    http://noemotionhdrs.net/
    Clothing and kit made in Marvelous Designer.
    In the gallery also: http://www.daz3d.com/gallery/#images/69997/
    Victorian 1880
    Otetiani (He Is Prepared). Just had to try a woodlands Native American. Mid-18th Century warrior of the Iroquois Confederacy. Marvelous Designer used to drape the Romantic Shirt and create the clothing.
    Gallery upload: http://www.daz3d.com/gallery/#images/70680/
    768 x 1106 - 506K
    wow it working it updated itself , no more beta check your DS beta is gone
    Love it !
    Merci beaucoup :)
    MEC4D said:
    Love it !
  • kyoto kidkyoto kid Posts: 41,987
    edited May 2015
    MEC4D said:
    Yeah ... you still need a card for your monitor or everything will be overloaded .. you will free the system from the GPU and have it working exclusive for renders or use it when the scenes are not bigger than 2GB
    Kyoto Kid said:
    MEC4D said:
    My info is from Nvidia Iray FAQ
    the scene must be able to be loaded into the GPU so in this case the lower memory card will be ignored if the scene use greater amount of video memory and only the GPU with higher memory will be used
    I guess we saying the same stuff just with different approach
    so in this case the 690 will be not used at all by Iray and ignored
    that why it is important to have all cards with the same memory to use all CUDA cores from different GPUs
    MEC4D said:
    iray will ignore the 2GB GPU and only utilize the 12GB GPU
    Iray will use whatever GPUs it sees within the system
    Logic contradiction (morning head explosion).
    If you set Iray to use the CUDA cores on a GTX 690 in a system, then Iray will be limited to using the size of the 2GB VRAM of the 690 - no matter how much VRAM is available on any bigger card being used.
    A Titan X used together with any card having less VRAM will result in Iray being limited to using the VRAM size of the lesser card.
    ...so the 690 would not work as a "de facto" Tesla compute unit even if not in SLI mode? Bugger.
    ...so that's the only advantage one gets with having both a GPU with a lot of memory and one with less.
    Post edited by kyoto kid on
  • DisparateDreamerDisparateDreamer Posts: 2,520
    Mec4D, i tried using one of your free lights for Iray, but i don't know how to install it. It is an Exr file.... Kept meaning to ask you how to use it. Also looking forward to other lights from you. And your unshaven 2, which i am watching for!
    edited May 2015
    Kyoto Kid ..that is correct
    belovedalia
    did you got the one with the scene ? you need to unzip and out it under MY Library
    and open the scene
    if you got just the HDRI then load it via the Environment where is Sky and Sun
    but you have to switch on too for Dome with Finite or Infinite Sphere
    and talking about Unshaven2
    I am playing lately with the Unshaven hair shader and seems it is good for other stuff like feathers and clothing just use the SSS only on one side polys but avoid clothing or will looks like wet waxy surface , bellow some quick tests , no textures just unshaven 2 shader .. figure is Olympia
    Hair and feathers are trans-mapped with opacity map , some hair opacity maps are bad as they are not white and black but gray to simulate transparency but now not need anymore
    710 x 910 - 206K
    710 x 910 - 280K
    710 x 910 - 271K
    710 x 910 - 291K
    710 x 910 - 317K
    Post edited by MEC4D on
  • Richard HaseltineRichard Haseltine Posts: 108,637
    Strictly speaking this isn't an Iray tip, but it's something I only just noticed.
    If you have a long series of connected links (chain, tentacle, whatever), you can enter Edit mode (right click on one item in parameters, toggle Edit mode).
    If you then select multiple sections of the chain, you can 'bend' ALL sections at once, curving it rather fluidly. Also, rotation will cause it to spiral nicely.
    It's also nice, if they are a linked chain, that you can click on a root item, then another item further down the list, and select everything in between.
    I had a lot of trouble with tentacles, hoses, and similar until I figured this out.
    You shouldn't need to be in Edit mode to do this. You do, however, need Consolidate Properties checked and Display Separate Items unchecked in the Parameter pane option menu.
  • thomas.s.wendelthomas.s.wendel Posts: 2
    edited May 2015
    removed by poster
    Post edited by thomas.s.wendel on
    belovedalia
    and open the scene
    I got "MEC4D_HDRI_exp2.0_outdoor_ambient.zip" when it upzips its an Exr file, "MEC4D_HDRI_exp2.0_outdoor_ambient.exr" and i don't know that format, how to install/where to install it. :/
  • BeeMKayBeeMKay Posts: 7,019
    edited May 2015
    exr is the ending of a HDRI file.
    You can basically install the exr (HDRI) File in any directory you want.
    For example, I have storied alll HDRI in E.\HDRI, which is nowhere near my regular content library.
    When you go to the Environment render tab, click on the small image in "Environment Map" and select "browse". Go to the location where you have stored the exr file. Select it, and it will be used in your render.
    Post edited by BeeMKay on
  • rovrov Posts: 46
    Has anyone been able to succesfully get the private build version of 4.8? All it want's to download is 4.7
    Mec ... you said it updates all by itself. I'm still seeing the public version .....
    In the meantime.
    Mercedes free .obj model rendered with lucian castle hdr map. Played heavily with scaling, camera settings, vignetting, bloom and tonemapping to get this particular kindda lensfilter effect look :-). Made one complete render with all settings and one of the car alone with clean settings.
    Put the car as a seperate layer on top in Photoshop. Applied a little motion blurr and put the layerstyle on luminosity with a 40% opacity and did an additional minor curve adjustment for the finishing touch.
    1170 x 675 - 438K
  • scorpioscorpio Posts: 8,533
    belovedalia
    and open the scene
    That can be used as an environment map
    365 x 628 - 54K
    edited May 2015
    Sorry double post
    Post edited by scorpio on
  • sheedee3Dsheedee3D Posts: 214
    Quick question...
    Where can i get Mec4d free light?...:roll:
  • Joe.CotterJoe.Cotter Posts: 3,362
    Jimbow said:
    Very nice. :)
  • Takeo.KenseiTakeo.Kensei Posts: 1,303
    edited May 2015
    MEC4D said:
    belovedalia
    and open the scene
    Would be better if you pack it up with a render preset. That is what I do so. That way I don't have to remember the other settings I used for tonemapping etc...and don't have to remember where I put that map and I also don't have to browse any directory. And that is very quick to reuse
    BTW very nice dress render
    Post edited by Takeo.Kensei on
  • Arnold CArnold C Posts: 740
    edited May 2015
    Really great render! Last of the DAZicans... The first thing came to my mind was the main theme from the Michael Bay version.
    Now I have to watch that ole movie again. :lol:
    My last Beta render from yesterday, tweaked G2F's MAT preset a bit. Fortunately, you won't need to tweak the textures of her.
    Lighting is "Stronewall" from HDRI-Hub. It's a bit dark so I used an ISO 200 setting on it. The "Faertara" outfit converts prettily, all you need to do is pulling the Glossy Layered Weight up to 1.0.
    Uh, almost forgot, I used DAZcjones' method on her eyes. Thanks for that.
    1080 x 1920 - 1M
    Post edited by Arnold C on
