Changing OBj into Fitted item?
deleted userdeleted user Posts: 1,204
I have a ring, and a Top. Their OBJ files from Zbrush but I want to turn them into fitable clothing and props compatible with Gensis 2 Female. How would one go about doing that?
  • Richard HaseltineRichard Haseltine Posts: 109,347
    If they line up with the zeroed Genesis 2 Male without needing to apply any transforms you can use the Transfer Utility - Edit>Figure>Transfer Utility - setting the Source to Genesis 2 male and the Target to your OBJ. Assuming the result works, select it and go to File>Save as>Support Asset>Figure Prop Asset - the names you enter for author and product will determine the folder names in the Data folder, then you will be prompted for a preset for loading the item which would go in \People\Genesis 2 Male\Clothing\Some folder.
