Fresh install crashes soon after opening
Daz used to work fine for me, then came to a point where my scenes looked broken and quickly (as soon as I played around with the viewer) the program crashed.
I uninstalled completely and reinstalled with no addon at all, just the basic program, and the problem persists.
Error file (attached) mentions a lot of "OpenGL error while drawing to the viewport: invalid operation"
I run Win 10, have a 3080 and the latest Nvidia drivers.
Thanks for any help, if someone has an idea,
  • IceCrMnIceCrMn Posts: 2,322
    edited July 2023
    "...NVIDIA display driver version: 516.94..."
    You need to install the newer GPU drivers first.
    then lets try it again and see if that works.
    If I recall correctly, you will need the 526 version or newer for the general release.
    You have that version...
    2023-06-09 16:03:39.478 +++++++++++++++ DAZ Studio 4.21.0.5 starting +++++++++++++++++
    You log says it's from:
    2023-06-09 16:03:40.622 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : NVIDIA display driver version: 516.94
    So this is an old log or you have something going on with your system clock.
    Someone with abit more expereince in software will hopefully help out with this part..
    2023-06-09 15:57:00.213 [WARNING] :: ..\..\..\..\..\src\sdksource\interface\dz3dviewport.cpp(4439): OpenGL error while drawing to the viewport: stack overflow
    pretty sure it's a memmory overrun, the program wanted to use more than was available so overran and crashed with OOM, Out Of Memory.
    Post edited by IceCrMn on
  • It was an older file, but I reran daz, it crashed again, here is the most recent crash log (I removed the old part, just kept today's.)  Most recent driver, still the same problem.
    txt
    txt
    July12log.txt
    154K
