1-Click PBRSkin Issue?
If you have two identical figures in the same scene and you click the script to change the skin of one figure, it automatically changes the other figure's skin as well.
Even if one figure is non PBR skin and the other figure has been converted to PBR skin.
Shouldn't the script know which figure is selected and only work on that figure's skin?
  • zombietaggerungzombietaggerung Posts: 3,868
    Maybe asking in the commercial thread would get you quicker help: https://www.daz3d.com/forums/discussion/640976/released-1-click-pbrskin-commercial#latest
  • crosswindcrosswind Posts: 9,673
    Haven't met such an issue... should not be like that unless you select both of the figures.
  • Silas3DSilas3D Posts: 757
    @zombietaggerung thanks for pointing @RexRed in the direction of my commercial forum thread!
    Whilst answered over there, for posterity I'll include a brief answer here too. Two or more of the same figures loaded into a scene with the same skin share those textures between them, they don't have separate textures.
    As such, any changes made directly to textures (such as gamma) will apply to all figures using that texture, which is unavoidable. It would be the same as loading the torso texture into photoshop and adding a tattoo and saving the original file - the tattoo would show up on both figures, as they're both using the same torso texture.
