Cant see nothing into Viewport
Hi there!
My viewport gone blank, the characters are there because I can render it, but cant see nothing
I tried changing style, and layout, activating viewport, reinstallin DAZ 4.21 but nothing changes...
Any help will be appreciated!
  • crosswindcrosswind Posts: 9,745
    Try this: Open Environment pane.. if the Type is Backdrop, switch it back to None..
    1444 x 1395 - 117K
  • Richard HaseltineRichard Haseltine Posts: 109,510
    It's also lost all of the Viewport controls, which might be a GPU issue. If you have two GPUs in the system (an on-chip Intel GPU as well as a stand-alone GPU) make sure that DS is set to use the stand-alone GPU; that is usually done by right-click on the desktop and select the cotnrol panel for the standard GPU).
  • Hi there! Wipped up all the previous content (except whats on the user library (characters, props, etc) ) and reinstalled again and it worked!
    Thanks for your support!
