Headshop
HI,
I haven't had any luck with placing hair in Headshop. I can drag a hair style over, but I can't adjust it. And it doesn't save with the figure.
Also, I get the following sequence of error messages when I try to use Genesis 8.1 figures:
No surface configuration has been recorded for this figure. Surface selection will need to be applied manually.
Unhandled exception has occurred in your application I you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Value cannont be null
Parameter name: image
Headshop closed because it could not create the necessary files.
It works with Genesis 3 and 8.0
Katherine,
it would be helpful to identify the HeadShop version you need advice with (i.e: HeadShopPRO 2023, HeadShopLT 2023, etc.).
For one, hair is adjustable sizable, etc - pls. watch how to video at 9:00 https://youtu.be/L-wZLeR2l7o and it also exports to User/Public/Documents/My DAZ 3D Library/Runtime/FaceShop/fs
I can also tell you that HeadShopPRO 2023 does not work with Genesis 8.1, only Genesis 3, 8, 9.
Also, tech support is available at [email protected], as you have sent me an email 2 days ago (and I responded).
Laslo
Hi Laslo,
I'm using Headshop 13.
Can you email to Tech Support ([email protected]) if you want to set up a tech support skype, please. (Works 100% of the time).
