install Attic Bedroom 2 with DIM
Excuse my english
After install with DIM you have only the Folder data and Runtime, missing the Folder Environments. The zip-file have all 3 Folders.
No Picture Problem with Upload
  • SofaCitizenSofaCitizen Posts: 2,105
    Yes, this product is broken. It's got the same issue as the freebie from a few weeks ago - the Manifest.dsx file is wrong. I'll raise a support ticket.
  • crosswindcrosswind Posts: 9,637
    edited July 2023
    Still, let's fix the problem by ourselves:
    0) Uninstall it with DIM
    1) Drag out Manifest.dsx file from 'IM00090266-01_AtticBedroom.zip' to somewhere on your disk
    2) Open it with EmEditor / Notepad++ etc., replace 'Environments/Attic Bedroom' with 'Environments/Daz Originals/Attic Bedroom', save the file.
    3) Drag Manifest.dsx back to 'IM00090266-01_AtticBedroom.zip', and throw it back to your Package Archive folder
    4) Install with DIM...Done.
    2168 x 1212 - 126K
    2560 x 1400 - 313K
    496 x 1302 - 290K
    Post edited by crosswind on
  • @SofaCitizen and crosswind thanks.
  • barbultbarbult Posts: 26,350
    Fixed with your clear instructions! Thanks for taking the time to help others.
    My pleasure ~ blush
  • Peter WadePeter Wade Posts: 1,672
    I installed it a different way. I looked at the installed files in DIM and saw that only the ones in the Environments folder were shown in a different colour which I think means they weren't there. I found the .zip file in DIM's downloads folder, opened it in file expoler and copied the Environments folder into my library.
    In this way, there's still no metadata in cms and you still cannot find this product in Smart Content, unless you never use Smart Content...
  • emanuela1emanuela1 Posts: 979
    Fixed with crosswind instructions, thank you very much!
    For SofaCitizen, which freebie from a few weeks ago is broken? Thank you!
    I don't use smart content so i didn't know it wasn't there. Your method is much better.
    It was the Personal Electric Transport that had the same issue at launch - there was a fixed version released about a day later tho.
  • Product Update!
    Problem fixed.
