How to prevent weight map brush painting spills across the other side?
It's very annoying when I tried to work weight map on the back of my cloth, but the front also get painted.
How to prevent this?
  • crosswindcrosswind Posts: 9,639
    Either keep the Radius of brush right on the geometry when painting weight , or select the related polygons before painting and tick 'Respect Selection', then it won't impact the weight on the 'opposite geometry'.
  • DartanbeckDartanbeck Posts: 21,985
    Also, if what you don't want to paint on is a different material zoneyou could use Geometry editor to Hide whatever material zones you don't want to be painted, then turn them back on when you're done. Works like a charm.
    If I want to paint a fairly large region, I'll select the polygons in the geometry editor first, then switch to the weight map and right-click > Fill Selected
    Since I have a falloff set in the Smooth section, it gradiates out from the polygons I have selected, making a smooth transition
