Texture problem
Hello
Recently I had problem problem with my HDD and after revovering my files, when I try to load a figure they appear like this and in rendering they become pink.
How should I solve this problem?
Thanks.
  • felisfelis Posts: 5,927
    What does your log say (Help > Troublshooting > View Log File)?
  • crosswindcrosswind Posts: 9,630
    Pls first check the texture maps to see if they're corrupted or not, for instance, open the file with an Image Viewer or Photoshop...
  • Richard HaseltineRichard Haseltine Posts: 108,551
    Pink can be a security software issue, blocking or deleting part of the iray code, though I thought that had been resolved in ecent builds. The basic texture application looks like the wrong maps or wrong UVs. It might be worth reinstalling the base content (Default Resurces and the Gensis # Starter Essentials for the figure you are using) in case theer was an issue with the recovered files, depending on what was lost and what you recovered rather than reinstalling.
  • I solved it, my files had been corrupted and after reinstalling them, the problem was solved.
    Thanks a lot!
