Exporting Normal/Roughness
Helle there.
I want to export the Normal/Roughness Map from a Genesis 8 Char.
I have not found the Option to export the Shaders manually. I saw a Tutorial on Youtube, but it does not work.
How to do it ?
Helle there.
How to do it ?
All maps (textures) can be found in the Runtime folder.
If you left-click on an image in the surface tab, you can choose browse and it will take you to the file location.
I find that 3Delight materials export much better than Iray, so if there are 3DL mats available for the product(s) you're trying to export, use those. If that doesn't work, do what felis said.
Sagan can export the maps; choose the Write Textures option.
