Can't seem to download anything with download manager 1.4.1.36
[Install manager 1.4.1.36] Fails instantly on everything and just shows the retry option. Tried to upload a screenshot but that doesn't work either.
OK this is what I am seeing in the log:
2023-06-18 18:24:14.966 [WARNING] :: SSL Error: 11 - The issuer certificate of a locally looked up certificate could not be found
2023-06-18 18:24:14.967 [WARNING] :: Network Error: : SSL handshake failed
2023-06-18 18:24:15.072 [INFO] :: Install Queue Finished: 0 min 0.0 sec
2023-06-18 18:36:59.700 [WARNING] :: SSL Error: 11 - The issuer certificate of a locally looked up certificate could not be found
2023-06-18 18:36:59.700 [WARNING] :: Network Error: : SSL handshake failed
2023-06-18 18:37:00.902 [WARNING] :: SSL Error: 11 - The issuer certificate of a locally looked up certificate could not be found
2023-06-18 18:37:00.902 [WARNING] :: Network Error: : SSL handshake failed
OK I fixed it after reading this link: https://www.daz3d.com/forums/discussion/609721/solved-new-pc-ds-not-installing-error
I installed the linked certificate file and it worked OK.
This was following a recent clean install of Windows 10.
