DA Circuit One
Hera
Will this one be released for M6 as well? I could imagine getting a bundle with both in.
Hera
It's a geoshell... it might already work for G2M.
As Lee says you can apply the geoshell to G2M with no issue.
You will need to change the UV Map to the included Warpaint Unified UV after it loads.
The texture currently has been created for the female form, so some of the lines may look a little odd on a male. Also there appears to be an issue with the way the texture is applied over the eye area of G2M.
There are plans for a similar looking set for G2M, made more with the male form in mind, but I don't currently have a time frame for it.
Here's a quick render with the Geoshell and the set on G2M rendered with Iray.
This is a cool item. The chest area may look a bit funky on the male. I intend to check it out. and see.
