A little trick I just discovered
2»
  • capitanquesocapitanqueso Posts: 8
    edited June 2023
    chris-2599934 said:
    Took me a long time to figure out how to set up your own keyboard shortcuts, but it can save you a lot of time once you do...
    • Go to Window > Workspace > Customize (or just press F3)
    • Find the action(s) you want to add shortcuts for (which can take some time as they're in a different structure to the one in the menu. Frankly, a straight alpabetical list would have been easier)
    • Right-click the action, select Change Keyboard Shortcut and press the key combination you want.
    I found out that if you change the default Shortcut/HotKey for "Preferences" under the Action -> Edit (F2) for anything else (i.e. Shift + F2), then you can use F2 (as you use it in any file manager to rename files) in the Scene Tab to change the name of the nodes, many of us strugle to time precisely the second click to rename something, so now you just select it or scroll up and down with the arrow keys and press F2 and you can edit one at the time all your cameras, lights, characters, inside a group or null by hitting Enter afterwards. Shame it doesn't work in the Content Library, if anyone finds out how to make it happen I would appreciate it! Even if it's a Script!
    Post edited by capitanqueso on
  • xyer0xyer0 Posts: 6,352
    I rapid triple click to rename a node.
