exporting Victoria
I have a strange problem: I need to export a Daz puppet from Carrara (Vic4); in Carrara, where the characters have been placed, a normal size V4 is holding a small (30%) V4... on arrival, in Collada, Fbx, or Obj, the small V4 is "blown up", ; apparently the re-size is not supported; would there be a solution? thank you for helping!
  • HeadwaxHeadwax Posts: 10,446
    you could try grouping them
    if all else fails you could group them and then export as an OBJ
