Techno Tabby problems
wiibbwiibb Posts: 0
Hi, I am having problems with the boots on Techno Tabby. I have V4 and when I put them on Techno Tabby they just do not fit and this is the same for other shoes,boots on V4.
Also what hair is that Techno Tabby has on @
http://www.daz3d.com/shop/techno-tabby-v4-a4-elite
Thank you in advance for any help with this model.
  • Richard HaseltineRichard Haseltine Posts: 108,517
    Check the pose folder - there may be a pose to hide or pose the feet, assuming that feet sticking through the boots is the problem you are having.
  • wiibbwiibb Posts: 0
    Yes the feet are sticking through the boots, OK thank you I shall try what you said. Have you got any Idea what the hair is use on Techno Tabby?
    :P
    I have now went through all the pose folder and tried them all and still no luck the boots just stay were they are without any movement?
    :P
    The foot fix poses, if there are any, would be for V4 not the boots.
  • JaderailJaderail Posts: 0
    edited August 2012
    No Pose file for Techno Tabby, You must do FIT TO on the boots after the load. Select the boots in the Scene Tab then in the Parameters Tab at the bottom do Fit To V4.
    Post edited by Jaderail on
  • HaruchaiHaruchai Posts: 2,033
    The hair looks like this one - Coiffure Celeste Hairstyle, currently on sale.
    http://www.daz3d.com/shop/coiffure-celeste-hairstyle
    Haven't used Tecno Tabby in a while but hiding/turning off visiblity on the feet and toes usually does the trick for boots.
    Thank you for the link to the hair
    :P
    Fit To works 100%. I tested it, I have the item.
