Ready - mcjCopyPoseAnim : example Aiko3 copies a 7192 frames Genesis animation
mCasualmCasual Posts: 4,607
edited May 2015 in Freebies
** 'tis ready **
https://sites.google.com/site/mcasualsdazscripts5/mcjcopyposeanim
if you have trouble downloading it ( the blue arrow!)
direct link to the zip file
https://sites.google.com/site/mcasualsdazscripts5/mcjcopyposeanim/mcjCopyPoseAnim.zip?attredirects=0&d=1
Elsewhere in the forum
there's MMD animations that were converted to BVH format,
but they specifically target Genesis figures
so i wrote and used this little script to copy bone by bone, frame by frame
the world-rotations of each bone and the world position of the hip
then i made this demonstration video
https://www.youtube.com/watch?v=nVVQF8ExhBc
since the root/figure bone is not implicated in any of this, you could use this to make dance trios !
( by moving the dancer using the root node, after the dance transfer )
Post edited by mCasual on
  • MusclemanMuscleman Posts: 3,094
    Funny :)
  • mCasualmCasual Posts: 4,607
    edited May 2015
    release will be wednesday ...
    well if you cant wait ... Beta : https://sites.google.com/site/mcasualsdazscripts5/mcjcopyposeanim
    edited May 2015
    Fig 1 - V6 and A3 are ready for the DS4.7 test ( which will be followed by a quick Ds1.8 test ) then the official release including the 1 paragraph manual :)
    Fig 2 - The selection order decides who is the donor and who is the receiver
    Fig 3 - And everything went perfectly well ... well after i set the timerange to the correct duration of 40 frames
    since their legs are not identical, Aiko's tremendous feet stability ( meaning mcjAutoLimb + mcjKeepOrient ) is not present for Vicky
    Fig 4 - optional delay
    fig 5 - Looks like it works
    i'm rush-posting it before midnight !
    note that there's my free script Blooper and other of my scripts which can cycle animation loops like that
    mcjEthercam can also do something like that but in an ethereal :o way
    one last note, if you select Aiko's right arm, then select the same Aoko's left arm,
    you can trick the script into having her receive her own animations
    480 x 270 - 663K
    564 x 450 - 109K
    600 x 338 - 966K
    932 x 534 - 109K
    480 x 270 - 108K
    edited May 2015
    ** 'tis ready ** ** 'tis ready ** ** 'tis ready ** ** 'tis ready ** ** 'tis ready **
    182 x 182 - 45K
    edited May 2015
    eventually i'll probably post a PC/Console/.exe utility which converts VMD files to english/text format files
    like the one you see below
    and a Daz Studio ( maybe poser too ) script to apply it to poser/daz figures
    i'm not sure yet but the figures seem to be animated using IKs, which complicates matters
    i had to make a Japanese to English translator,
    then i had to make a CodePage932 to Unicode converter
    the rest is positions, rotations (quaternions ) and morph strengths
    the header is just this
    var signature = "Vocaloid Motion Data 0002";var model = "^“cK‘º–v‘æ“ñver.1.";var nKeyFrames = 15037;
    800 x 800 - 322K
