Link Wardrobe to Genesis?
I just purchased and downloaded the Morphing Business Suit:
http://www.daz3d.com/morphing-business-suit
Which says it is compatible with Genesis, male, female and more. But if I load a Genesis male, I dont get any business suit option under Wardrobe?
If I select nothing, than I can add the shirt, pants, jacket, etc to the scene, and they do indeed seem to mostly fit my man, but then if I pose him, the shirt stays in ye ole T-pose.
How do I make everything work together?
Thanks so much! That seems to do it.
Though when I do, it says, "You've chosen to fit an unsupported item onto the figure. Would you like to try to convert the item to fit the figure?"
Does this mean the Business suit will remember in the future that it works with Genesis? If not, is there some way to make it remember?
Thanks again.
It looks to me like you're trying to use the business suit on Genesis 2 Male.
This product is made for Genesis 1, not G2M: "Genesis Male" is not G2M, it's Genesis 1 with the male morph applied. That's why it asks you if you want to convert it.
Once you've used autofit to convert it you should be able to save the converted version so that you don't have to re-convert it next time you want to use it on G2M (save as figure asset I think, I don't have DS here to check).
Leana is correct. That is also why the outfit wasn't showing up in your Smart Content when you had your figure selected. The outfit was not designed for Genesis 2, rather the original Genesis base figure. I autofit outfits all the time to my characters, mainly V4 and M4 clothes to base Genesis since that's the only figure I use. I don't use the G2M of G2F figures.
Thanks guys, this is all pretty new (and confusing) to me.
So I don't need to write off outfits designed for Micheal or Victoria? That's good to know.
I dont think Daz 4.7 I just installed even came with Genesis 1, just the Genesis 2 male and female. What do you think is better about the original Trampy?
Thanks again for the help.
Yes, Genesis Starter Essentials is included, along with G2F and G2M SE...and that is Genesis 1.
If I open Daz with a blank scene, and click on Figures - all I see is Genesis 2 Female Starter Essentials, and Genesis 2 Male Starter Essentials. I really don't think I got Genesis 1.
Is there some where I can go to acquire Genesis 1?
Thanks Tramp.
Just for The Record - I didn't "forget" to install Genesis Starter Essentials, as I have no idea what I am doing. DAZ instal manager never suggested it. I did figure out where my Product Library is though (online, not in DAZ), so I am learning...
Really helps to have cool folks like you all, instead of just hoping to find answers in the Helps, which I have largely found not to be.
Any of you fine folks have much experience taking characters, hopefully rigged and animated, into Lightwave and/or Modo?
Nope. The only 3D programs I work in right now are DAZ Studio and Hexagon; the latter for modeling. Yeah, anything you purchase, whether it be individually or as part of a bundle, will be in your Produce Library for you to download. Personally, I always manually download and then install it myself. I don't use the DIM (that acronym should be reason enough)
