a basic question: how to show a half sink empty box?
functionfunction Posts: 285
edited May 2023 in The Commons
Just realized that I can not solve this simple problem: Show an empty box and its insides when half sink in ground.
Any idea?
Post edited by function on
  • GordigGordig Posts: 10,805
    The ground would have to be transparent, or at least translucent. You could try a cube primitive with a volumetric shader (done in Iray through SSS).
    Or, if you mean that you want just that part of the ground to disappear, as if you're submerging the box into water such that the contents stay dry, you might want to look at Gescon.
  • crosswindcrosswind Posts: 10,276
    Press Ctrl + 8 to check the geometry (segments) of the ground object, see if there's any chance you can use Geometry Editor to select the polygons (or create a ground / floor by using Primitive - Plane with enough segments), then hide or delete the selected polygons and adjust the scale of ground and/or box as needed.
    2059 x 1311 - 271K
    2062 x 1312 - 945K
  • functionfunction Posts: 285
    Thanks for your answer. I tried to make a volumetric cube but it can not achieve my request. Here is the parameters I used on it:
    Refraction Index: 1.00
    Refraction weight: 1.00
    Thin walled: Off
    Transmitted Measurement Distance: 30.00
    SSS Mode: Chromatic
    Scattering Measurement Distance: 25.00
    SSS Color: 0.54   0.54   0.54
    SSS Direction: 0.50
    It can make a fake volumetric effect, but can not hide the ground inside.
    Gescon looks insteresting, I may check it later.
    Let's assume the ground can not be transparent or UV modified, and the Box has a complex shapes such as an empty pool, is there an easy way to put that empty pool inside the ground, and show the inside pool bottom?
    edited May 2023
    Thanks. That is an idea, but not accurate, especially the 'box' is a complex shaped stuff, and the ground is combined by many real tiles (not tile shader), or you want to turn the box's Y rotation for 20 degree.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,565
    do 2 renders (or 1 spot render) with the plane visible and hidden, layer in Gimp/Photoshop etc, erase the bit on the top layer
    (or mask in a video editor if doing a movie)
    edited May 2023
    Yea ~  if they're with complex shapes / polygons, DS cannot handle it with native functionalities as it's not a modeling software after all... But actually it's just a boolean operation, without buying the plugin, you may use Blender to make it for any shape,  within 1 min and all free...
    2058 x 1308 - 562K
    Post edited by crosswind on
  • HavosHavos Posts: 5,704
    edited May 2023
    I have the gescon plug in and you can create the effect you are after. It has the advantage of showing the edge where the box meets the ground, if that is desirable.
    It depends on the final look you are trying to achieve on whether or not this is the best approach, or one of the other methods mentioned above.
    1024 x 1024 - 164K
    1024 x 1024 - 173K
    Post edited by Havos on
