Render Question
Hi,
I'm trying to render a high quality picture from Daz Studio Pro 4.8 with an alpha channel so that I can layer it with other pictures in photoshop.
I am rendering it as a .png. When I render the scene with 3Delight I get the proper channel. But as soon as I render it with NVIDIA lRAY (which is the quality I need) it starts rendering a part gray/ part white back ground. Any ideas? Attached are the two renders. Thanks!
  • Richard HaseltineRichard Haseltine Posts: 108,745
    In Render Settings, under Environment, turn off Draw Dome and Draw Ground. You may need to edit the option under Alpha too.
  • edited December 1969
    Hey,
    That was the problem...thanks for the fix!!!
    All the best.
