Eyes look bloodshot - Genesis 9 Female
Hi Good people,
Please has anyone experience this when rendering with Iray before? What am I doing wrong please?
Waiting patiently
  • RaukoRauko Posts: 38
    edited May 2023
    Go into render settings .. and Optimization .. and change the "Instancing Optimization" setting to either Speed or Memory ..
    Post edited by Rauko on
  • crosswindcrosswind Posts: 9,629
    @Rauko001 I still remember that I was watching your video the first time I encountered this problem nearly 2 years ago. blush
    I don't actually remember the last time I had this happen so I don't even know if the solution still works .. laugh .. but if it does .. yeah, there's a video for it!!
  • Worked like a charm! thanks for taking out the time to respond to me. I have been watching a couple of your tutorials as well.
    Also, since you are here. How would you recommend I get a night scene in Daz studio using Iray?
    THANK YOU.
    edited May 2023
    Couple of methods I've used in the past .. can be as simple as just dropping a blue tinted Point light into the scene and playing around with the brightness  ..also I've actually used a sunny environment HDRI and dropped the Environment Intensity so that the sunlight becomes highlights from the moon. You might still have to drop a blue-tinted point light somewhere to give it more of a nighttime feel .. but just play around with things like that .. It won't work with every HDRI but try a few different ones and you might get lucky!
  • THANKS! I will explore. And thanks for the tutorials!
    Exactly !! cheeky
