HELP!!!! Scene won't appear on viewport but visible when rendered
NEW TO DAZ!
The scene (https://www.daz3d.com/100-hdris-gates-of-avalon) won't appear on the viewport, but it appears when I render it.
Tried loading other scenes and it works fine just this particular scene is invisible on the viewport
  • Richard HaseltineRichard Haseltine Posts: 108,687
    The Viewport appears to be using Texture Shaded Drawstyle - that will not show most advanced featrus, including HDRI environments like these.
  • crosswindcrosswind Posts: 9,645
    edited May 2023
    Yea, if you use Dome + HDRI map, the ' HDR environment' could be only visible when you render or switch DrawStyle to Nvidia Iray preview in Viewport ( Ctrl + 0 ).
    Post edited by crosswind on
  • ObsiObsi Posts: 22
    Thank you so much!
    Thank you so much!
